98 tahoe pass door problem?
That's what I thought so he has the motor and switch wires backwards on on of the relays. Easy mistake easy fix. And I posted wrong info early you are right t money pos trigger white and blue wires at relay pack
so if it's an easy fix do i just switch the blue and white wires? or just leave it alone
If its 5 wire then its not blue white. Help me out t money. I'm getting old memorys shot. However the alarm either has built in relays for 5 wire or he used external relays the wire must be changed at relays tell him the switch and motor wire is crossed
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
but is it an easy fix i can fix right now because my truck is outside, and i'm taking the truck to him tomorrow
yea the wires u need are in the driver kick. My link
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
lock is light blue. unlock is white
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
oh sorry
hold on
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
i found the correct wires but theres a factory relay right on top of the gas pedal and looks like theres the blue and white wires he has a wire connected to each but im confused?
479-418-3056 text me a pic of the relay you are talking about
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
