Subs arrived today!!!
Overall I'm impressed with these subs...a bit plastic, but whatever...Finally I got some detailed stats on them
PW2-15m
1300 watts MAX power handling
550 watts RMS
110 Oz. Magnet
2" Aluminum Voice Coil
Mounting Depth: 7.08"
SPL 88 dB
Fs: 32 Hz
Vas: 67.882 cu. ft.
Qms:2.598
Qes:1.282
Qts:0.858
Xmax:0.43"
I don't know what half that means but I figured some of you guys would lol
So what do you guys think...considering I picked up both of these for under $150.
could someone please answer my wiring question from previous posts in this thread?
and one more thing...PA recommends 2.72 cu. ft. per sub sealed but after doing some measuring in my trunk I realized the most they can get is about 1.6 cubes per sub.
Power Acoustik fubar 12
sony xploding amp
2 ft^3 box @ 35hz
The amp is rated 200wrms x 2 @ 4ohms but can handle a 2 ohm load on each channel...It's also rated 500wrms x 1 @ 4 ohms.
Will I be better off with a sub on each channel @ 2 ohms or bridged @ 4 ohms....or is the amp internally regulating those to the same exact thing?
It doesn't make sense that its rated more gross power bridged than stereo. 2ohm stereo is the same thing as 4ohm mono on a 2channel amp.
Does that help?
sony xploding amp
2 ft^3 box @ 35hz
i honestly dont think they will blow the seal of the rear window. i think youre good the way it is.
Yeah but my trunk will rattle its ass off, and what do you mean the way it is? Subs facing the rear?
sony xploding amp
2 ft^3 box @ 35hz
apply more sound deadener on the trunk and rear deck.
I'm just gonna fire forward bc the box would block the air from flowing unrestricted into the car...
What do you guys think of teh subs? I think they look awesome, but they are not nearly as solid as my fubar...and .43" xmax on a 15 seems pretty shoddy.
Edited by 07mazda3s
sony xploding amp
2 ft^3 box @ 35hz
  • Who's Online   0 Members, 0 Anonymous, 565 Guests (See full list)
