If you can find a 12 or 15 basket for it with the same bolt pattern, just cut the cone/spider out, unscrew bolts and there you have it. Make sure you put tape covering the gap.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Didn´t read "PSI" maby their can recone your sub. To your 12´s and 15´s 125 up the sub $$ for wood glue and screws + your, your father or your friends boxbuildingskills.
"in the abundance of water, the fool is thirsty" Bob Marley
i said he could hit up psi?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
I have a old type s 12" :-)
Type s might fit. Try it or search for bolt pattern for the two. Just not a big fan of the type s basket but guess it serves the purpose if fit and you can find parts for it.
Ah! It must be a Friday brain fart!... Carry on
  • Who's Online   0 Members, 0 Anonymous, 2907 Guests (See full list)
