2nd Battery in, amp (Kicker ZX1000.1) mounted up top:
Bare box 3.6cf @ 34hz.
Primed:
At this point i wish i would have 45'd the top face plate:
Sub in, with direct connect leads:
Where it will be chained thru (on both sides):
Inside was fiberglass'd also:
All In:
Box is only 3.6cf (3.4 after displacement of sub) Wish i could have made it bigger but it still sounds clean and i like it alot.
Lemme know what you guys think :)
Edited by Jesseland
Amp: Kicker ZX1000.1
Sub: 1 AudioQue HDC315
Box: 3.6cf @ 34hz
2nd Batt: Shuriken BT-35
seal off those 2 big openings between the sides of the box and the car and it'll be way louder ;)
what he said
Why you didnt angle cut the top and bottom? Nonetheless, nice work!
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
I wanted to but i wasnt too sure how to go about it so i didnt bother.
I was in a big rush to get the box done, i thought it would look fine as it was, apparently not haha.
Box: 3.6cf @ 34hz
you can use trim pieces of mdf, i've never done it before so im not 100% sure how to do it.
Lol... Same here but i've learn to be patient and make it right the forst time. Unless its a test box
make a beauty panel, easiest way is take a large piece of cardboard and get it to fit perfectly across to completely seal off the cabin from the trunk then transfer that to a piece of mdf and slide it in infront of the box attach it and your done
Cardboard cutout to test fitment and refine is your friend before cutting any mdf on that one
