miniSPLlancer Posted October 29, 2011 Report Posted October 29, 2011 My audio control line driver does 9v output. My Credcendo bc2000 takes 6v input. Will it hurt the amp to send 8-9 volts to it?? 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
2loudisjustright Posted October 29, 2011 Report Posted October 29, 2011 I couldnt tell you for sure whether or not it would hurt it, but i ran an audio control eq line driver one time that boosted preout voltage to 9 volts as well, and i ran it into a alpine amp that said only up to 4 volts and i never had any problems. 2000 zx2: Rebuild with 8 12s on a 10k underway!! MY BUILD LOG
miniSPLlancer Posted October 29, 2011 Author Report Posted October 29, 2011 I turned down the line driver and it doesn't sound as good. Just wanna make sure I can turn it up a little without damaging the amp. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
n8ball2013 Posted October 29, 2011 Report Posted October 29, 2011 if it cant handle it the amp "should" go into protect. Please note I said should. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
AA98hoe Posted October 29, 2011 Report Posted October 29, 2011 There's a lot of variables.. run it if it doesn't give you problems. My dds don't like a lot of input voltage they start acting crazy blew a few subs becajuse of high input voltage clip TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
soffhands Posted October 29, 2011 Report Posted October 29, 2011 dont do it turn it down you can blow the preamp in the amp
