How do I go about setting my gains with the DD-1 while using an EQ that has gains at 45Hz, 100Hz, 700Hz, 2kHz and 15kHz? I was thinking of creating tones in audacity & setting 100 - 2khz with a -5db tone & find the clipping point for each frequency & 15khz with a -10db tone since songs normally roll off around 10-12khz. Would this work? Or should I use a -5db tone all around?
Edited by eltortuga94
System:
Basically Stock
In process of upgrading
the device only detects 40hz and 1000hz. those are the only frequencies you can test
you have any idea how i would set the gains while the signal is coming from my eq?
because my eq also has a bass output with a min to max and an over al volume for the sub+mids highs
would i just set them half way sub output and volume then set the volume on my headunit then set the gains ?
