georgiaspl Posted November 3, 2011 Report Posted November 3, 2011 could a RCA line driver reduce alternator whine? I have one laying around, and thought i would install it just to see if it would.
MrSkippyJ Posted November 3, 2011 Report Posted November 3, 2011 it is best to remove the noise rather than try to cover it up. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
georgiaspl Posted November 3, 2011 Author Report Posted November 3, 2011 it is best to remove the noise rather than try to cover it up. i've tried everything lol. I'm thinking it may be in the amp. Im sending it off for repair in a few day's, but figured if the line driver made the noise go away then I wouldn't have to send it in
MrSkippyJ Posted November 3, 2011 Report Posted November 3, 2011 line driver wont make the noise go away. Best case senario is that the amp is where the noise enters your system and adding a line driver gives you signal head room and lets you lower your amps gain. More signal, less noise. But the noise will still be there AND if there is noise entering the system, there is something wrong. You are not doing yourself any favors by keeping the noise in your system. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
georgiaspl Posted November 3, 2011 Author Report Posted November 3, 2011 line driver wont make the noise go away. Best case senario is that the amp is where the noise enters your system and adding a line driver gives you signal head room and lets you lower your amps gain. More signal, less noise. But the noise will still be there AND if there is noise entering the system, there is something wrong. You are not doing yourself any favors by keeping the noise in your system. well in that case I will just send my amp off and not try the line driver. Thanks for your time
MrSkippyJ Posted November 3, 2011 Report Posted November 3, 2011 no problem. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
