Couple days ago I wired everything together to make sure everything works before I finished trimming everything off, Figured out the max headunit volume and gain etc. Then started to play the system and let it go for about 20mins, I then turned my RCA Level controller all the way down and noticed my subs where "rumbling" I guess is how you could explain it so I shut my truck off and they kinda quietly went "thump" I had a problem with it doing this before I did my rebuild but sense then I have ALL New RCAS,RCA Level controller,A brand new DC5k,Brand new LVL5s etc, Everything is new except for the headunit. So I figured the problem must be the radio because that is the only thing that is not new and i was having this problem before, I ordered a new one which should be here in a few days so i will see if that fixes my problem, But It could also be my Remote? but that wouldn't cause the "Rumble" As for how everything is wired. I have the big 3 up front, 1 Run of power off the ALT to the back batteries and 1 run from the front battery to the back, then 2 runs of ground from the front batter to the backs, Then the 5k is hooked directly right up to the batteries in the back. The remote wire goes into the 5k then I have another that goes from the 5k to the 4 channel. All my RCAs are ran on one side of the truck and the 0gauge and remote is ran on the other side if that matters.
Thanks.
Edited by LoudNLow931
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
What kind of headunit?
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
Have you grounded the rca outputs?
2003 corvette z06
No I haven't, I did read though that pioneers have that problem. I'm hoping the new one(Well its a refurb like mine, I dont like the new pioneers) will fix this lol. If not I will try grounding the outputs.
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
Yeah it sounds like the pico fuse to me. I'll find a link I have saved and post it to see if u can fix your radio.
2003 corvette z06
I found a few, dont want to post it cause its another caraudio forum, but basically do this with every RCA output...?
http://i47.photobucket.com/albums/f157/lilnick510/DSCF0992.jpg
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
The link I posted shows step by step directions to fix it. Yeah do it to all the outputs
Edited by vettedude102
2003 corvette z06
I had the same problem with an avalanche, problem turned out to be the balasts for the HIDs, But your problem sounds like its most likely a ground loop issue.
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
  • Who's Online   0 Members, 0 Anonymous, 4742 Guests (See full list)
