moh.vze.com Posted November 12, 2007 Report Posted November 12, 2007 This "static" noise that I am getting is hard to describe, but it seems to occur whenever and instrument is played. I don't know if it could be a specific frequency that's causing it or what. My system: Front comps: [DLS MS6A] http://www.edesignaudio.com/edv2/product_i...products_id=521 Amp powering components: [Nine.2] http://www.edesignaudio.com/edv2/product_i...;products_id=45 Headunit: http://www.crutchfield.com/S-ue32nAxApJl/A...=Kenwood+MP5032 Two 12'' 13kv.3 Subs in the back: http://www.edesignaudio.com/edv2/product_i...;products_id=31 Amp Powering subs: [nine.2x] http://www.edesignaudio.com/edv2/product_i...;products_id=47 Note: we disconnected the subs when we tested the front comps so it can't be anything to do with the subs and such that's causing the "static" noise. By the way, our guess to what may be causing the "static" noise is the headunit (which I really hope is not the reason because I spent 100$ on it last year). DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Guest MegaloManiac Posted November 13, 2007 Report Posted November 13, 2007 maybe interference in the rca lines..
reinke Posted November 13, 2007 Report Posted November 13, 2007 if you have a high pass filter turn it on to 125. if not you could try bass blocker. the problem is usually to low of a frequency trying to play through them ----reference's---- meade916
Guest MegaloManiac Posted November 13, 2007 Report Posted November 13, 2007 if you have a high pass filter turn it on to 125. if not you could try bass blocker. the problem is usually to low of a frequency trying to play through them he is using passive crossovers, amps are set on "full" (im assuming), he cant mess with all that
