Light "static" Noise From Front Comps?
This "static" noise that I am getting is hard to describe, but it seems to occur whenever and instrument is played. I don't know if it could be a specific frequency that's causing it or what.
My system:
Front comps: [DLS MS6A]
http://www.edesignaudio.com/edv2/product_i...products_id=521
Amp powering components: [Nine.2]
http://www.edesignaudio.com/edv2/product_i...;products_id=45
Headunit:
http://www.crutchfield.com/S-ue32nAxApJl/A...=Kenwood+MP5032
Two 12'' 13kv.3 Subs in the back:
http://www.edesignaudio.com/edv2/product_i...;products_id=31
Amp Powering subs: [nine.2x]
http://www.edesignaudio.com/edv2/product_i...;products_id=47
Note: we disconnected the subs when we tested the front comps so it can't be anything to do with the subs and such that's causing the "static" noise.
By the way, our guess to what may be causing the "static" noise is the headunit (which I really hope is not the reason because I spent 100$ on it last year).
Guest MegaloManiac
if you have a high pass filter turn it on to 125. if not you could try bass blocker. the problem is usually to low of a frequency trying to play through them
he is using passive crossovers, amps are set on "full" (im assuming), he cant mess with all that
  • Who's Online   2 Members, 0 Anonymous, 1272 Guests (See full list)
