My neighbor just gave me a 400 watt power inverter. and i mounted it under my back seat, and i dont want to have to flip the switch on and off from under the seat, i want to put one in my center console on the inside so i can turn it on and off whenever i want without going under the seat. it looks like 10 ga. that came with it, what do you guys think would be safe? because it will be hard running 2 pieces of 4ga. out of a toggle switch all the way back to the inverter :P so im trying to go as small as i can without losing power/causing problems.
Edited by Krazykid122
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
how would i go about hooking up a toggle switch to it? do they make 8ga. quick disconnects?
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
ive been doing some research, i cant find 8ga. quick disconnects to fit on the back of the toggle. alot of people are talking about using relays or silinoids.
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
Figure out the amp draw of the inverter and use an appropriately rated relay. By using the relay you wont need 8 gauge wires for the toggle switch.
how would i hook 8ga up to the relay? those are some nice sized cables, and i cant find 8ga disconnects.
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
no one?
02 Dodge Durango
1 Fi SP4 18" .v2
XS D3100 up front
