Beginner Posted November 18, 2011 Author Report Share Posted November 18, 2011 Thanks! Should I start with the Lite Weight, or just use the putty cote? I'm guessing I should use the Lite Weight and sand it down first and then use the putty. Thanks for the replies, if you something I should do different just let me know. This is going to be painted with high gloss so I want it to look good! Link to comment Share on other sites More sharing options...
CarAudioFab Posted November 30, 2011 Report Share Posted November 30, 2011 Thanks! Should I start with the Lite Weight, or just use the putty cote? I'm guessing I should use the Lite Weight and sand it down first and then use the putty. Thanks for the replies, if you something I should do different just let me know. This is going to be painted with high gloss so I want it to look good! Def the lite weight first then the putty -Mark Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel Check out my forum section here on SMD for my builds and tutorial videos! Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication Link to comment Share on other sites More sharing options...
