I've already modified my dash to fit a double din and now I'm relocating my ac controls. The only place I can move them to has become a challenge. The ac control housing is a square box and I'm trying to relocate it onto a rounded surface.
After it is molded in I will be cutting 3 holes for the knobs and the icons on the controls. It will sit behind the panel and will need to be thicker in certain spots to fill in the gaps between the ac unit and the bezel from the backside.
Here is what I'm trying to do.
I will be keeping the "bodyline" so I will not be molding that part in below the controls. This will also be painted to match the outside of the car. Thanks!
Edited by Beginner
log on to urethane supply website.
Find flex filler
go to town
enjoy sanding.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I think I'm going about this all wrong? I've got my 3 holes in my 1/16" plastic piece but everytime i bend it too far it breaks. What can I do to make this work?
Can I use aluminum and then bond it to my plastic, do my body work and then paint it? Or will plastic and aluminum not bond to each other without it cracking?
you are not going to bond plastic and aluminum well. You can goop up enough adhesives to make it work but its not a desired method
are you heating hte plastic.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I got my plastic to work and I used a product call Q-Bond. It's meant to work on plastics and works very well.
I'm now ready for my body work. Do you see any problems before I start with the body work?
Everything has been sanded smooth, do you see any early signs of cracking? Do I need to fill in every pin hole or just leave that to the body filler?
Thanks!
Both sides have been bonded with Q-Bond and it's very sturdy. Am I ready for body work? It looks better in person.
Edited by Beginner
the only ting i dont like is the ridge wehre the bond is. Id want that to be smoother before starting.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It is smooth. Where are you talking about exactly? The top section that I molded in?
I know it looks "wavy" all around the edges, it's just how q-bond is after you sand it. Everything is smooth.
I'm new to this, so please let me know. ;-)
Run some rage gold on it, sand it.... And you should be ok
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
You don't NEED rage, those should work alright. Just don't put it on too thick, which shouldn't be a problem by looking at what you're planning on filling.
Rage is just a better product overall. Application, sanding, etc
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
