1995 Chevy Truck Build! THE HULK. Updates!!
TwoStroke, I bought a gallon of resin from autozone once and the top had hardened closed like you described. I drilled through it and saw how nasty it was inside. I took it back and got a full refund. Just a heads up for next time. Resin shouldn't really go bad or harden until hardener is added, so I knew something was messed up.
I just used it haha. At the time I didn't have a way to drive and get any from anywhere else. It sucks forsure tho. Ill never buy resin from there again. I love this 3m I got from home depot though! Thanks man.
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
trev,
If you want the edges to clean up better you need to glass past the edge and then cut it once its hardened. Just an option if you want it better. Keep up the good work your doing great and i love watching your progress.
trev,
Thanks casey! Yeah I figured that out, problem is it is hard to tell while its in the truck. But I think Im kinda getting the hang of things. Thanks for the advice
My Truck Build
Started glassing.. After going out into my truck to see all the tape and my piece of wood on the floor. I had to re do it all. But its all good, I started glassing and its actually starting to look like a headliner! I actually think this may just work!
My Truck Build
Got some work done. I worked all day on it. First thing I had to do was figure out the dome light. Originally I was going to replace it with an LED light that wasn't a direct fit. But I wanted it to 1 come on when the door is opened. But also have a switch to come on if I drop something or my friend needs to see something. I didn't think that was possible and I don't have $1 do my name. So I integrated the stock one. I cut out a frame but I could not get two of them symmetrical and all we have is 1/2"
flush trim bit. So what I did was use the one 1/2" frame and then I cut a piece out of the headliner board I had kicking around. That added enough depth for the light to clear. After doing that I cut out the headliner with the dremal and started spreading bondo. I thought I had more bondo then I did, turns out the stuff in the bottom was a thin layer of wet bondo over a bunch of dry. End result is I didn't have enough bondo, so what I did was spread spot filler all over it and hope for the best. This project has costed way to much already and Like i said I have no money. Here are the pictures.
This is the dome light holder I made.
Here is the headliner with the stretched fabric, with resin. You can also see where I ran out of bondo and started using spot filler. I hope to god this works. I will be sanding and depending on how much work needs to be done, possible wrapping tomorrow.
I didn't have fleece so I used an old shirt. Lesson learned, its really hard to stretch a shirt tight and staple, trimming of the extra without the shirt coming loose. I think it will work tho. It still needs spot filler.
Its coming along.
My Truck Build
Oh and, VOTE FOR ME SOTM. (: If I win there will no longer be back seats in my truck.
My Truck Build
Well I had a hard time getting the back as smooth as the front. My dad has this genius idea so lay cloth over it, resin it and it definitely smoothed it out. I got it wrapped, it looks great! I couldn't be happier. Gonna put it in tomorrow when my dad gets home. I also figured out how to get the sunroof slider down so I could suede it. I didn't have enough suede so I had to do it in 3 pieces just so it looks half way decent until I get buy another yard. I cant decide if i want to re do the visors and put them back in or not. Anyways, I had to take the glass out and then the slider just unclipped and came out. It took 10 mins to get out, and 3 hours to get back together and I still have to do it one more time when I get the suede, whenever that will be. What a pain in the ass. Here are the pictures!!
Came out perfect!! I love it! Also, what do you guys think about... a roll pan and a shaved tail gate. :nuts:
My Truck Build
The finished product looks real good Trevor! Good work!
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
the head liner looks great.
but with your truck i wouldnt do a roll pan. At least to me i dont think they look good on lifted trucks.
but hey its your truck do what you think looks the best.
99 Gmc sierra extended cab
front speakers: DB drive 6.5
back speakers: DB drive 6.5
amp: none right not
subs: none right now
Future
waiting to get my 2 skar vvw 8s installed
