miniSPLlancer Posted November 13, 2011 Report Posted November 13, 2011 Like the title states, I'm looking into getting 2 FI BL 12's and adding another Crescendo bc2000 to the one I have now. Will this be enough power for them? I have a 270 Mechman and plan on getting 3 more batteries with what I have now. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
crunkjuice1 Posted November 13, 2011 Report Posted November 13, 2011 one amp per sub? Strapped? your final ohm load you can wire sub down to in parallel or separate? Are the FI's upgraded?
miniSPLlancer Posted November 13, 2011 Author Report Posted November 13, 2011 one amp per sub? Strapped? your final ohm load you can wire sub down to in parallel or separate? Are the FI's upgraded? The amps will be strapped, the subs in parallel and the FI's will just be the regular BL's. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
bassahaulic Posted November 13, 2011 Report Posted November 13, 2011 As long as the power is clean they should be ok. Just make sure the signal is clean. VERY clean.
