Hey everyone, new to this forum. A couple questions on my build im starting soon. The car is a 93 Toyota Corolla, Equiptment is going to include 2 Sundown Sa-15s off of my current Rockford T1000bd.
So obviously these arent going to fit in my trunk, I cant get even 1 15 in there without a crap prefab box. Right now I have that same amp powering a Type R 15 in a 2.5cu box tuned at 31hz. So its home is in my back seat with the backrest taken out. It sounds best when the sub and port are facing into the trunk.
Im going to build another box for the sundowns, but from you guys experience hopefully ill be able to make up my mind on how im going to build this box. Ex. subs up, port facing trunk im thinking would be loudest. Or maybe seal the trunk off completely to increase cabin pressure...
Any experienced feedback would be greatly appriciated.
93 Toyota Corolla
Big 3
1/0 Wire
Rockford P400.4
Rockford T1000.1BD
Rockford R-Series Components up front
POS Kicker KS650 Coaxials rear deck
2 Sundown SA-15s
Alpine CDE-123 Head Unit
Custom Sub Box 5.8cubes 31hz
sound deaden the trunk very well and do 2.75 to 3 cubes at mid 30s for a single sa 15.. use 13inches of port per cube or MORE (i run 14 to 15" per) sub up port back to drivers side..
i have the same workcar
i run 2 rockford hx2 10s (i believe that the model i got them forever ago..beefy 3" coil motor).. and 3 cubes net in a slot port box tuned to 28hz with 14" of port per cubic foot..powered by a t10001bd.. BIG 3 upgrade and a single xs3400 in back and im golden for a work car..
Thanks man, so if I build the box for two of them, have the subs facing up with the ports facing the back? And I also have deadened the trunk very well from when I had 2 12s in there. I also have the big 3 done, batteries will come after the subs, stock alt.
93 Toyota Corolla
Big 3
1/0 Wire
Rockford P400.4
Rockford T1000.1BD
2 Sundown SA-15s
if ur planning on trying BOTH 15s in the trunk...i would for sure try to seal them off and fire forward into the cabin..
i personally think a single 15 would be sufficient,, be easier to feed also with the stock alt n such
Sorry if I confused you, I plan to have the subs in the backseat. With my amps in the trunk. And I'm only going to be putting probably a lil over 1000 end plus my 4 channel so a hart or two should be alright for now. So with the subs in The backseat would subs up and port facing back sound the best?
93 Toyota Corolla
Big 3
1/0 Wire
Rockford P400.4
Rockford T1000.1BD
2 Sundown SA-15s
I meant 1000 watts, and a couple batts
93 Toyota Corolla
Big 3
1/0 Wire
Rockford P400.4
Rockford T1000.1BD
2 Sundown SA-15s
Yes that's exactly what I'm doing. With the port blowing into the trunk through the huge gap left from removing the seat.
93 Toyota Corolla
Big 3
1/0 Wire
Rockford P400.4
Rockford T1000.1BD
2 Sundown SA-15s
when i was 18 i had a 4 door dodge neon..i had a solo x 18 in place of the back seat..i had sub AND port facing forward and it hammerd..
then did another design with port firing upward..that worked VERY well also
1 solo x 18 and 2 boss 3000ds lol..my system forever ago
  • Who's Online   0 Members, 0 Anonymous, 778 Guests (See full list)
