Why not design your own to spec and use torres box calculator here on the forum?
I can give you a couple reasons why:
1. Major noob for box building, I can give you the way it should be made just not the dimensions for cutting the mdf.
2. I didn't know there was a box calculator here on the forum.
3. Like to see other peoples opinions and designs.
4. Learn new things from it.
5. At last, some people have fun building them so why not?
http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator/
Thanks ^^ but i still have no experience with building..
I can give you all I know so far then. Those dimensions are what I can work with not the actual dimensions I for see for the box dimensions. I'm looking for the most from the subs for ground shaking bass I guess to say. I've seen the graph from winISD where it should be, which is 4 CuFt at 30 hz, 2 cubes per chamber if seperated. Thats about all I know.
Someone gave me a sq build, he gave me 4.07 cubes after displacement with 26.3 hz for a flatter response but I'm not looking for that.
Edited by caveman
Building is a learning experience man! Try your best and post it up!
Please nooooooooooooooooooooooooooooooooooooooooooooooo D':
Your right its a learning experience, so why not help someone in the need for knowledge ;D
If you help me I will show the whole process of me building it and ill post it. My second box I build Ill do it myself.
Edited by caveman
I've heard that for ext cab trucks the better orientation is subs forward port up, but i'm kind a noob too, so I'm not for sure, just maybe something to look into?
2008 Toyota Corolla
-Skar VVX 12 D4 (2)-Skar SK1500.1-Pioneer DEH-80prs
...ill be trading vehicles, but I have some dimensions, wishing someone will check them.
But if I need to face everything up I can my box is only 14 in.
Enclosure Specifications:
Fb = 30 Hz
Vb = 2 ft^3 (per chamber)
Subwoofer Displacement = 0.18 x 2 = 0.36
Double baffle
Port Internal Width (A) = 2 in
External Width = 37.83 in
External Height = 14 in
External Depth = 24 in
Cut List:
* All Dimensions in Inches.
* Wood Thickness is 0.75 for all Parts.
External Enclosure Parts:
Fronts(2 parts) = 32.33 x 14
Back = 37.83 x 14
Left & Right Side = 23.25 x 12.5
Center Divider = 21.75 x 12.5
Top & Bottom = 37.83 x 21.75
L Ports Internal Assembly Parts (2 of each) :
Front to Back = 19.75 x 12.5
Extension = 8.27 x 12.5
Can someoneeeeeee check these specs, id appreciate it, thanks in advance if you do.
Edited by caveman
  • Who's Online   0 Members, 0 Anonymous, 3135 Guests (See full list)
