this box look good for a BTL 18?
curtdakota
ok some of you may know that i was gonna switch from my BTL 18 to 4 10's (or you probably dont know) but, i decided im gonna save my money, and build a different box and get a better amp for the BTL and see what i can really do with it, basically the only difference on this box design to my current on is my current one is using a slot port, and im switching to aeros with this new box. and by switching to aeros im saving just enough space to cut down the height of the box to stay under the back window line. this is going in a 2005 extended cab dodge dakota by the way.
now my question is would this be enough port area?
http://i560.photobucket.com/albums/ss47/curtis96olds/BTL18box.jpg
i think you are a bit low, should be 14 to 16 foot per cub, you also have some other issues, woofer displacement and bracing will be more than .1 each, and common port walls should be 3
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
i think you are a bit low, should be 14 to 16 foot per cube
i know its 12-16 with a slot port, but this is gonna be 3 6" aeros, i thought you could use less port area for aeros? or am i wrong?
oh i thought you wanted advice on the slot port, yeah i am pretty clueless about areos myself
port walls will be zero because there aeros, woofer displacement i was just guessing on, but it will be between .1 and .2 so its not a huge difference anyway, and bracing wont be more than .1 because i wil be using threaded rod which will take up probably less than .1
how much power is gunna go on it?
thats the thing, im not sure on what amp im gonna run on it yet, possibly a AQ2200D, or a sundown saz2500 or if i can find a used saz3000, or i might decide to step up to a AQ3500D
so lets say 2200-3500 watts lol, i know thats a broad range of power, but i just honestly dont know what amp i want to run yet.
  • Who's Online   0 Members, 0 Anonymous, 2030 Guests (See full list)
