Ive been messin around with torres box calc and i have some spare wood layin around. While i save for my new subs i want to build a ported box for my mtx 4000 10" i pretty much got it all figured out between the 12 volt calculator and torres. I want the box tuned to 33 htz. the problem is i cant figure out how to find port width? please help me! Ill be usin a slot port btw. this is my first ported box
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Just keep playing around with numbers until you get 33hz . That's what I did when I was playing around with it.
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
haha thanks man but id like to really learn how to do this :/ i am very passionate about it
My Truck Build
Port width..? Just try to stay within a 9:1 Height to Width ratio to avoid tuning shifts. Basically, just make the port height as tall as your box minus 1.5" (for internal measurements). Then just punch a number in for port width that sets you in the correct port area range. Usually between 12"-16" of port area per cubic foot of box volume is a good general rule of thumb.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
okay i did an 11 inch high port, 2 inches wide and that gave me 15.94 inches ^2 of port area per foot. then i put that in on 12 volt slot port length calculator and i got 32.42" long. put that in on torres and it puts me at like 51 hrtz. What am i doing wrong??
My Truck Build
Go to the "# of common port wall" box and put 3. What are you using for dimensions?
Edited by loudNlow87
Sub Amp: AB 450.1
XS D3100
Come on 150!
12Hx15Wx20D I am using 1/2" wood. and dont i have 1 common wall because the port will be on the far side? so the side of the box will be used as a port wall?
My Truck Build
Don't use 1/2" plywood. It's gonna flex like crazy. And that box is just too small. By the time you tune it low enough you have about a 1/2 a cube of volume. Go wider. And using the side of box for a slot port is 3 common walls.
Sub Amp: AB 450.1
XS D3100
Come on 150!
shit this is confusing haha. thank you for your help tho
Edited by Twostrokeking
My Truck Build
