Options for Fi SSD's
I am wanting to buy 2 Fi SSD 12's and needed some help picking what upgrades to get. So i need a more detailed explanation on the options available for the SSD's.
Questions:
What's the difference between Dual 1 and Dual 2?
What does the internal lead option do?
Also i'm not new to car audio just have not dealt with this much power. What all will i have to upgrade in my car to get the best results?
Edited by moneil10
If youre not new to car audio, I would think you would know what dual 1 ohm and 2 ohm mean. :ehh:
But Dual 1 ohm (actually .7 ohm) and dual 2 ohm (actually 1.4 ohm) coils are just different resistances to wire up the sub to get a final load to the amp. Higher resistance usually equals lower power, unless you have a Rockford Fosgate CP amp.
I would suggest, depending on how much power youre going to put to them getting the flatwound coil which isss..
Flatwind coil: The flatwire coil option simply helps the power handling of the sub. The coil has more surface area to dissipate heat and will take more power then the regular round wire coil that comes in the ‘stock’ version of the sub. This option will also make the sub tend to be more prone to ‘peaking’ for a budget daily driving sub where you don’t have to use a ton of power to get maximum output and sacrifice sound quality a little bit.
and the Cooling option. Internal lead which seems to be a new option is Im guessing the tinsel leads are sandwiched in between the spiders to reduce tinsel slap on the lower notes. Unless its something different.
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
I will probably get the dual 2 SSD's and i will probably get an amp around 1500-2000w rms x 1. But like i said im not new but i dont know as much as i should lol. So which ohm load should i use and how would i wire them to achieve that?
Edited by moneil10
Well i knew what Dual 1 and Dual 2 just needed a better explanation i guess. I will probably get the dual 2 SSD's and i will probably get an amp around 1500-2000w rms x 1. But like i said im not new but i dont know as much as i should lol. So which ohm load should i use and how would i wire them to achieve that?
It depends on which amp you're planning to use..
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
For Dual 1 ohm
For Dual 2 ohm...
The same wire configurations, just the top one would be a final load of .5 ohms
And the bottom one would be 2 ohms
I dont think there are any amps that are "stable" at .5 ohm or one that is covered under warranty, but i know DC amps and AQ amps should be fine as long as you have the electrical to back it up
Edited by Trey_Dog650
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
  • Who's Online   1 Member, 0 Anonymous, 1527 Guests (See full list)
