x6369x Posted November 16, 2007 Report Posted November 16, 2007 Anyone know the price per square ft for 3/4" polycarbonate at Tap Plastics? I'm trying to figure out if I want to put a window in the box I'm building.
jack Posted November 16, 2007 Report Posted November 16, 2007 Anyone know the price per square ft for 3/4" polycarbonate at Tap Plastics?I'm trying to figure out if I want to put a window in the box I'm building. i think it is between 20 and 30 psf for the acryllic http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build" (1) DC AUDIO Level4XL 10 (2) PowermasterD2700 batteries ALL FOR SALE TEAM DC AUDIO TEAM DIRTFLOORPOOR
w87will Posted November 16, 2007 Report Posted November 16, 2007 Sorry about the tread Jack but Im also planning on putting a window in my box. will 1/2" Polycarbonate lexan work better than 1" Acrylic or will either work? Its just that the Polycarbonate is cheaper at http://www.estreetplastics.com/category_s/53.htm and if so Im going to pick up some of that. Thanks
w87will Posted November 17, 2007 Report Posted November 17, 2007 Anyone ever use acrylic or polycarbonate? or have knowledge of either product? if so I need some advice on which to use.
goinpro Posted November 20, 2007 Report Posted November 20, 2007 if you have one close to you then they usually have like s scrap box there you can pick up cheap. Theres is a difference between poly and acrylic but I believe for what you are using it for it does not really matter. If it were semiconductor equipment it would be different 2005 Nissan Altima 2.5 S HU: AVIC-D2 Fronts: ARC Audio KAR KS6006 Components AA Poly Mids/ CDT CW-19 Tweets in kicks Front Amp: Profile AP400x2 Rear Fill: None Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps) AMP: RF t10001bd x2 (1400-1500 @ 1 ohm) Wire: Welding Supply/Lighting Audio 1/0 Power/Ground Zero Noise 2.0zn RCA (x2) 260 Amp Iraggi Alternator
