The enclosure is 14.88^3 internally.....wanna tune it to around 37hz...open mouth area is 4 3/16 h by 42 w
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
So that is correct, I can extend the ports like that and I should work....never built a wall so....
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
Is it the same distance from the port wall to back wall (horizontal) as it is from one port wall to the other (vertical)?
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
Yes, it is...Using www.12volt.com slot port calculator, in order to get to 37 hz, it says I need my port to be 12 inches long....Now is that 6 inches top and 6 inches bottom, or 12 inches top and 12 inches bottom?
Edited by ChrisLun
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
The vertical width should be twice the width of the horizontal since both chambers are exiting to one vent. Or the horizontal widths should be half the vertical. Which ever way you did the math to get the tuning.
Edited by loudNlow87
Sub Amp: AB 450.1
XS D3100
Come on 150!
Say it calls for a 4" port width. You would keep the port 4" from the back wall. Where they connect to one port would be 8" so each chamber will see a constant 4".
Sub Amp: AB 450.1
XS D3100
Come on 150!
The horizontal is 3 3/4 deep while the vertical is 8 1/4 both sides.....
The port is off the wall 4 3/16 rear, and the same off the floor and top
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
Then the vertical should be 8 3/8". 4.1875 x 2 = 8.375.
Like this. Don't mind the Paintshop. I got lazy.
Sub Amp: AB 450.1
XS D3100
Come on 150!
