My Level 3 can accomodate a 1/4-20 if thats any help.
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
I use 1/4 on my xls.. make sure your sub is centered before you drill holes... my major issue is t nuts like to push out and or cross thread easy.... glue them in from the back a dab of ca works well.. its goin to be a bitch if your speaker cutouts aren't tight lining up the holes but t nuts are a lot stronger and allow you to take subs in an out without stripping holes with screws
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
If you use screws make sure to use bigger screws, not necessarily longer but thicker with a bigger screw head. (twss)
I used a slimmer screw for my first wall and the heads snapped off of them after 8 or so months. Choose wisely or it could potentially cost you an amp or sub or both. :drinks:
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Note the size of the head and how its attatched.
Next to a bic for size reference:
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
This, or make the hole a hair small and press them in with a C clamp.
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
ive used screws on lvl 5s in my wall... granted they were bigger screws, they worked fine
unless you got a sub heavier than a lvl 5, which there are not that many.. i doubt you need bolts
im using 2 inch screws right, do u thing it would be okay?
or should i use tee nuts and bolts.?
do you know the size of the mounting wholes for the lvl 5s?
it really cold out ha.
Tee nuts and button cap torx bolts......make it hard for the thieves.
then they will prolly stab the subs haha
and thanks everyone for replying!
But, a recone is a whole lot cheaper than a new sub
Edited by bobobass
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
