Those 3.0's are notorious. People always think it's a squeaky belt...but it's not. It's your distributor....pull that bitch out and check the pin that holds the gear on, If that shit goes you are fucked because it operates your oil pump and if it goes it will lock your motor up tighter than a catholic school girl on prom night.
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
Hopefully....the gear on the end of your cam spins a gear on the distributor which connects to the oil pump shaft. There is a roll pin holding the gear onto the distro that likes to shear off......if your oil light comes on shut the motor asap or you'll be screwed.
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
Do you already know how to remove it and reinstall it correctly?
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
OK cool.
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
