2001 F-150 Supercrew Sundown Build!!
have some pics on my phone but not uploading them, box is still just setting done all sealed up waiting on port to arrive. hopefully it will come tomorrow. When my sax1200d gets here, does this sound like a good idea, knu 1/0 ofc then 200amp fuse,then more knu 1/0ofc, then distro block with 1/0 input and 2 outputs (4gauge),then 4 gauge to sax1200d with 150 amp on that circuit and just leave the other circuit on the distro open with a 50 amp fuse for when i add a component amp??
PSI and Sundown audio FTW!! 2001 F150 crewcab Sundown z12v.2 on a sax1200d! 1/0 welding wire!
4inch precision port aero is what im going with right now, i know its small but if i want, i can always go bigger to a 6
i know its not a necessity on that little of power but i would get a reducer 1/0 to 4 and just get a normal anl bolt fuseblock, :shrug: its how im going to run power to my kappa four
edit: THIS
edit: THIS
explain more of what you mean. maybe sketch me a pic in paint or something, i dont understand
btw port out drivers side
thanks dood that will so save me some money! im wondering should i fuse it on the amp end even though the sax1200d has a fuse
that's up to you. but generally if i dont go under the car, with my wire, i dont usually fuse in the back. and with that truck you should be able to find a grommet to squeeze wire threw and have no issues. but that fuse block in the pic is like 5-6 bucks. you can find them cheap online. im not going to link you there cause SMD sponsors might not like that... :peepwall:
