So I bought (2) Fi Bl 12" fully loaded @ 1 ohm.
What is everything I need to get it running?
- Amplifier: probably SAZ-3000d
- Ported box enclosure
- Which electrical cords? Big 3?
- Which XS power battery for 3000 watts?
- Am i missing anything else?
Thanks everyone for your help!
Edited by Hadec
Working on my first car audio build ever!
Currently have:
- 1996 Lexus LS400 sedan
- Diablo Hellfire Proto Amplifier
- (2) 12" Fi Bl Subwoofers
- Vented subwoofer enclosure from Perfect Soundz
- Installed by Perfect Soundz
Needs:
- Battery: probably XS Power 12V 2400
- "The Big 3"
What vehicle is it? You're still going to get a decent amount of drop. That amp's a beast and it's hungry.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
yep do the big 3 in 0 gauge wire for sure, cheap upgrade and it helps a lot surprisingly.
i've got a sundown saz 2500 for sale if your interested and 2 batteries.. 100 per but let me know , just trying to help ya out.
Make sure you run 0 gauge power wire, ground all that ...
If you decide to go with XS look up what group number fits under your hood but you'll most likely want 1 or 2 bats if your running 3k rms
"This next song goes out to everyone within a 5 block radius"
I have a 96 Lexus sedan. So I will do the big 3 in 1/0 Gauge Power / Ground Wire?
And when they say 12v, 14v, 16v... Is that the size of the battery?
Will this batt work? http://www.soundsolutionsaudio.com/store/products/XS-Power-D1200-12V-AGM-Battery%2C-Max-Amps-2600A-%252d-3000W-.html
Edited by Hadec
Currently have:
Needs:
- "The Big 3"
3 K-watt´s mean complete power, ground and Big 3 in 1/0 gauge, you will be fine with a D3100 under the hood, if it would be to less you can add a 2. batt later
(XS will have a powersale early next year) and dont forget to fuse your wires.
"in the abundance of water, the fool is thirsty" Bob Marley
So what wires do I need to setup my amplifer/subs?
Currently have:
Needs:
- "The Big 3"
Yep 50 feet of 0 gauge wire will be enough. You'll need power wire, ground wire RCA"s, remote and big 3 you'll need 3 runs... there's many tutorials on this forum on how to do the big 3. Like the other guy said make sure you fuse your power wire and when doing your ground scrap away paint so you get a nice connection
Edited by Jmoney18
Bunch of 0ga, a ~17ft remote lead, RCA's and some ~12ga speaker wire.
Sub Amp: AB 450.1
XS D3100
Come on 150!
