If You Want Enclosure Plans Then Here Ya Go!
andym85
Anubis
what u said is correct...although i get a length of 7" for 40hz (with 7.5" i get 38hz...but not a major difference)
thanx
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
hi boys and amatt for this subwoofer help
max dimensions-----------------------------H45Cm x W97Cm x D45Cm in mdf wood 1.9cm
type of subs----------------------------------Impact 15" 6715 svc 2ohm
number of subs-----------------------------2
desired tuning freguency----------------50-55 and for a take a good number in bass race
type of vehicle-------------------------------fiat punto 02' model
positions of sub and port--------------subs back!! port back in the center of subs
for the plans thangs amatt85
Guest Nismofreak
k here is another project for my buddies car
1 phoneix gold rsdc
2.5 cubs or 2.0 cubs
35hz
12 d x 28 l x 14 h
champn252
the port starts behind the baffle and the actual cut length of it is 15.5"....the 18" is the effective length due to the end correction
Is the end correction anything I should worry about? I promise to leave you alone after this :lol:
2012 Honda Accord
Radio: Pioneer AVH-4200NEX
na...just cut the wood for the port 15.5"...end corr. is nothing U need to worry about when buildin it though...
i likes me some audio stuff...
need help with a box design.
2 12" W7
20d x 32w x 16h
34hz
sub facing back, do you think it would make a diff. if i pointed the port up in the car?
thanks in advance.
i can go deeper in the depth, if needed to
Thanks for the plan I need one alittle smaller
-max dimensions----------------- 36 l x 36 w x 20 h
-type of subs----------------------DD 3515d
-number of subs------------------ 4
-desired tuning frequency--------36 hz
-type of vehicle-------------------95 buick station wagon
-position of the subs and port---subs up port back
Pioneer premier deh 510
2 Crescendo BC2K
4 dd 3515
zero gauge all around
big 3
thank you amatt, definite props for spending time on all these
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
hey amatt can you help me out with my enclosure,
-max dimensions----------------- W-36 H-16 D-16
-type of subs----------------------kicker cvr 12
-number of subs------------------ 2
-desired tuning frequency--------37 hz
-type of vehicle-------------------06 kia sorento
-position of the subs and port---subs back port back, port in the middle of the subs
any help is greatly appriciated.
