If You Want Enclosure Plans Then Here Ya Go!
andym85
- Height: 16 Width: 23 Depth: 17 used the calc. if im right it should be around 2.79ft^3
- 12" Type R dual 4ohm
- 1 sub
- 30-35 hz what you think will sound best
- Daily Bumping
- 1997 Toyota Camry
- Sub facing towards the back
- one round port 1.5-2in radius
trying to make an easy box
this is my first custom box so pvc is where ill start thats why ill have a round port and im tryin to keep some of the trunk space so if i ever need it i can use it
Thanks!!
I need plans for a box for 2 Kicker L7 12".
Its for daily playin.
49" long & about 30" wide thats the space i have to play with in my tahoe.
Thanks a lot!
"Da 2tone HOE from the 520"
ok...im gonna sit down and do all of these right now...i will have them up tonight...late
and nismo...i promise i will pm u that other box witht the round ports first...sorry for procrastinating fellas!
i likes me some audio stuff...
Guest Nismofreak
thanks alot man. I got one more box design for a good friend of mine
I will donate some money man
about that one u posted above...its gonna be under 2cubes...with those dimensions it almost exactly 2cubes gross...but after subs/port ur looking at probably 1.75-1.5cubes
Guest Nismofreak
uh doesn't matter. That would work
floodwagon
this is too small
kiaman
im not really sure about the math when doing ports down the middle that run the height of the box that have to make a turn....i can for sure do it with the port on the side though, or the port on the bottom/middle...
