all of the "braces" were inside or, in some weird way, part of the port. in which case the braces wouldn't displace any air...
i see a lot of inconsistency in the designs, which makes me think you're not the one designing these. it almost looks as if you're copying pictures from different places.
i'm not trying to bag on you, just want to know where you're getting these from.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
It's all good, it's a forums...it's open discussion.
Um well a while back, I had some sundown z12...both being pushed at 1k rms, the ported box I had.....well the ports kinda blew out. So...I had to put some braces in between them...and it did just fine...and then I blew my subs. lol.....at the time I had a few broom sticks and I was kinda drunk and was too lazy to cut the MDF board...so I used the broom stick instead. Thus the reason why I got the idea.
and the "take up the volume" box I was talking about was the box with the 4 circles in it. The one with like 6 braces in the middle of the port...was a support...so the air pressure wouldn't blow it apart...
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
If air pressure is blowing your box apart there then there's a structural or design issue. The holes are doing nothing but causing excess restriction, which means more built up pressure.
Hammerdown... 1%
