Posted (edited)
Came up with the design for a friend of mine for two SA-8"s, power is gunna be a SAX-1200D.
Ive never used aeros, but i know that you dont need quite as much port area per foot then slots.
is this enough port area?
Subs will be downfiring in a centerconsole of a 2004 Dodge ram, port firing back
Edited by RickyFriery97
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
will there be no bracing? o 45s?
most likely not, really not needed with such little power
then it looks fine... the port area is within appr range for aeros.
thank you sir, most likely gunna go with this design. could you tell me what the range is for aeros?? never used then before..
Ttt, could someone tell me the pros and cons of having a smaller amount of port with aeros? I saw samewhere the rule of thumb is around 9-12 per cube.
