What Size Alternator
i looked around trying to figure out howw big of an alternator i will need but i couldnt really find anything specific,so here i am asking for an answer.any help will be greatly appreciated.the car is a 99 grand prix,the stock alternator is 110 amp and i have also done the big 3 and the lights still dim a fair amount.
heres my setup
2-12"alpine r-type 1242d 1,500w peak/500w rms
2-6x9 infinity 693.7i 300w peak/2-110w rms
2-5.25 polk audio db5250 2000w peak/10-100w rms
1-profile ap1040:
80w rms x 4@4 ohms
125w rms x 4@2 ohms
disregard this crunch amp
1-crunch gp1100 (i think):
275W x 2-Ch @ 4-Ohms or
550W x 2-Ch @ 2-Ohms or
1100W x 1-Ch @ 4-Ohms Dynamic Music Watts
im replacing it with a HIFONICS BXi2006D and i will be runnuing at 1ohm
- D-class Amplifier
- Power Handling:
- 650W x 1Ch.@ 4Ohm
- 1300W x 1Ch. @ 2Ohm
- Peak 2000W x 1Ch.@ 1Ohm
- Frequency Response @-3dB: 20-250Hz
- Damping Factor: >250
- Signal To Noise Ratio: > 95 dB
- THD + Noise: < 0.1%
- Variable Input Level Control: 0.2V - 9V
- Variable Input Level Control: 0.4V - 18V
- Input Impedance: 47k Ohm
- Input Impedance: 20k Ohm
- Phase Change in Degrees: 0-+180
- Variable Low-Pass 24 dB Octave: 35Hz - 250Hz
- Variable Subsonic Filter: 15Hz - 35Hz
- Bass EQ: 0-+18 dB
- ±18dB Variable Bass Equalization @ 45Hz
- 180° Variable Phase Control (15 to 35Hz)
- Dash-Mountable Bass Remote Control Included
- Variable 24dB Subsonic Filter
- Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply)
- Balance Line Inputs for our 18-Volt Line Drivers
- RCA Inputs
- RCA Line Outputs
- Remote Bass Module Included (through RJ-11 Jack)
- Gold Oversized 2-Gauge Power Connectors
- Gold Oversized 8-Gauge Speaker Connectors
- Dimensions : W-16.50” x L-10.39” x H-2.63”
im also going to add another set of polk audio DB5250 components in the kick panel,also how big of an extra battery would i need in the trunk,i dont want to replace the one up front cause i just bought it 3 months ago
  • Who's Online   2 Members, 0 Anonymous, 546 Guests (See full list)
