Help building a box for 2 12" Kicker Cvx's
Ok I understand so just change the dimensions up to what I said and make the port those dimensions and I should be good? But yes I will put pictures of the build when I start it will be this weekend or the beginning of the week.
Current Set-up:
* Two 12" Kicker Cvx's in a custom box tuned to 34 hertz
* Mb Quart onyx 1500.1d pushing my Kickers at 1 ohm
* Jvc Headunit
* Kicker Ks68 door speakers
* All 4 gauge wire
I will probably just stick with the one you drew up it is very detailed and straight forward I should be able to do that. I am going to have lowes make the big cuts and I will do all the littler ones. Thanks again
Current Set-up:
* Jvc Headunit
* All 4 gauge wire
Getting ready to call lowes or home depot how many sheets of mdf will I need and what else do you rec. I know you sai titebond glue anything else?
Current Set-up:
* Jvc Headunit
* All 4 gauge wire
I am trying to download the torres box tuning calculator but it will not let me everything I try any help thanks?
Current Set-up:
* Jvc Headunit
* All 4 gauge wire
titebond glue, a right angle triangle, caulking, 1 1/4 inch diameter dowels, drywall screws, and plenty of clamps.
and you should only need one sheet of MDF. you could make yourself a cut sheet with the dimensions i provided.
use plenty of glue and take your time
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
Thanks guys the box is finished and installed in the truck it sounds great. I will start uploading pics of the build now.
Current Set-up:
* Jvc Headunit
* All 4 gauge wire
Yes It is still drying I played for 2 mins but I am going to let it dry some more it dried all day and last night.
Current Set-up:
* Jvc Headunit
* All 4 gauge wire
Current Set-up:
* Jvc Headunit
* All 4 gauge wire
I think you need a URL. tinypic works decent if you don't have a photobucket account or something similar.
More box builds
  • Who's Online   0 Members, 0 Anonymous, 1303 Guests (See full list)
