Mechman Alternators
Something wrong with my Mechman?
the smaller fuse would restrict it but i dont think that is the issue...change it and see and have u checked the alt postive wire yet? do u have a voltage reglater?is it turned up? ur getting voltage drop like the alt is barely even sending out put..
That fuse was on the alt positive wire to the battery, tomorrow i´m gonna change it for a 300 amps fuse or just run it directly without any fuse, i don´t have a voltage regulator, and i how can i know if the alternator is barely sending out put? i just don´t know what the hell is going know actually, i just know i have an aternator that costed me 500$ , 4 runs of 0 gauge, a big ass battery in perfect condition and a small amplifier :S
I am having same issue with my mechman 270 alt. Getting voltage drop to low 11 volt range. Running a dc 3k and 2 xs power d3400 batts. Curious to see what matt says. im prob gonna give them a call.
Damn!! since you installed it? i´m getting frustrated already :S
do you have an amparage meter? try using one and see what is the output on the alt. i dont even get that bad of a voltage from my stock alt running a brz2400, i do have 2 kinetik hc2400 though
edit:i would get 10.8 volts on my other truck with a stock 40a alt and would drop to 9v with everything on and making everything shut off.
Edited by Miguels
As i always says, there are a few things that i don´t have a clue about car audio, i´m kind of a noob about electricals, first HO alternator i´ve ever owned is this mechman and i´m very frustated right now, how the hell can i check how many amps is my alternator really sending??? i do have a clamp meter...
To test the alternator output use a current clamp meter around the alternator + lead.
Turn on whatever your load is and read the output in amps.
http://audioforum.te...22;t=003982;p=0
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
When I got mine last year I asked matt about fusing the line from alt to battery and he said not to do it because if something were to go wrong something would actually mess up in the alt. Call and ask and double check that.
For real??? a fuse can hurt an alternator?? if that true, he never told me anything, as i said before, my alternator didn´t even come on a box with at least a mechman logo, no manuals, no nothing...
I might be dumb or blind haha, did i miss how to test the amperage the alt makes? i didn´t see that anywhere, and remember that i´m from Panama, no autozone or anything like that around here lol
just clamp it and put a load on the alt (turn everything on and play at full tilt)and you will see the amp go up, and no the fuse cant hurt the alt. its the other way around if you dont have it and you have a short somewhere it could mess up the alt.
  • Who's Online   1 Member, 0 Anonymous, 1566 Guests (See full list)
