Box Design For Trunk Car
either way your last design looks good with a port height of 3"
should be a sweet build
looking forward to more
? L7 or L5 and what amp
L7 on a BXI 1606 @ 1 ohm.hope it pounds.right now i have a box thats 5cube with 4 4"ports but i get alot of port noise.it doesnt even sound good at all
Edited by byron2817
NEED TO GET LOUDER!!!
well thats ~400-600 over rms, depending on how much that amp really pushes. whats the length on those ports in the box you have now and the volume. each port in would have to be almost 18 inches long to achieve a tune of 37 in 4.75cuft box and that is plenty of surface area. the smaller the box the longer the ports need to be so if your current setup is lets say 4cuft, the 4 ports would need to be 20 inches in length... does this help with why it might not sound "good"
woops didnt see 5cubes... whats the tune frequency currently and length of ports now
so the ports would have to be 17" in length each to be 37-38hz fb
Edited by decafcappucino
you enclosure is tuned somewhere around 42hz if its 5cuft net volume, drop it down to 35 and your peak drops from 54ish, to 44ish, big difference on the low end, and your rolloff isnt so steep, songs like jeezy and gorilla zoe will sound alot better.
does the l7 sound sloppy, weak high end bass, almost no low bass.... a little more info goes a long ways
take a vid!! :excl:
  • Who's Online   1 Member, 0 Anonymous, 951 Guests (See full list)
