Bracing Help Box Guide idea
SlamminBeats
is wood good for bracing inside a box? Ive seen ppl use those really long screws and those look alot more legit. Also how do you fiberglass the inside of a box to seal it up?
I think it would be a good idea to have a section pinned about what material is best for a box. For example, MDF or birch, and like what type of glue to use, and when you should use a thicker baffle. etc etc
i would rather use the long screws personally, you resin the entire inside and some people often like to add some glass to the corners and resin those, as for wood. i use MDF because thats what i like. some people like birch but at this point its personal prefrence. Loctite ||| IMO is the best wood glue along with nails works just fine and anytime you question your baffle ou should add more. never hurts
well said. Do i need to pre-drill the holes? i have a nail gun and compressor
by really long screws do you mean all thread?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
and yes adding too many screws/nails can be harmful.. after a certain point your compromising the integrity of the wood and making it weaker
power: dd m4
yeah i Would use threaded rods to support it, and 3/4" MDF board. That is what works best for me.
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
hell i just used about 80oz of resin and 2 2x4's for my bracing, thing doesnt move a millimeter, single baffle too, although its way to small :pardon:
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
thinking about doing .75 mdf, double baffle, resin on the inside, two rods for bracing top to bottom, possible one 2x4 left to right, subs up, port middle facing back, in my hatch. now for the tuning frequency... heheh <_<
yep lol its called all thread...and i like it alot better than wood for bracing :)
power: dd m4
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
