Bracing Help Box Guide idea
SlamminBeats
is wood good for bracing inside a box? Ive seen ppl use those really long screws and those look alot more legit. Also how do you fiberglass the inside of a box to seal it up?
I think it would be a good idea to have a section pinned about what material is best for a box. For example, MDF or birch, and like what type of glue to use, and when you should use a thicker baffle. etc etc
i would rather use the long screws personally, you resin the entire inside and some people often like to add some glass to the corners and resin those, as for wood. i use MDF because thats what i like. some people like birch but at this point its personal prefrence. Loctite ||| IMO is the best wood glue along with nails works just fine and anytime you question your baffle ou should add more. never hurts
well said. Do i need to pre-drill the holes? i have a nail gun and compressor
and yes adding too many screws/nails can be harmful.. after a certain point your compromising the integrity of the wood and making it weaker
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
hell i just used about 80oz of resin and 2 2x4's for my bracing, thing doesnt move a millimeter, single baffle too, although its way to small :pardon:
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
yep lol its called all thread...and i like it alot better than wood for bracing :)
power: dd m4
  • Who's Online   0 Members, 0 Anonymous, 1000 Guests (See full list)
