extremeauto Posted December 14, 2011 Report Share Posted December 14, 2011 i got my Mechman back for my 95 Honda passport from being repaired today and i was surpized wen i finaly got it re installed my voltage when i first got it was 13.7 cold and @12 warm with a load .....but now my cold voltage is 15.1 .warmed up i am getting 14.2 and 13.8 warm under a healthy load of 3000+ watts i did have a issue when i got this with low then no voltage...(every1 gets bad parts from time to time)also i may have been part of the reason it failed due to the wrong size ring terminal on the positive output bolt of the alt...but after discussing it with matt we decided to have u ship the right size terminals on some 0 gauge. well it seems to do the trick now i run a 3 extra batts(100 amp hours total and i will be adding more)i am running a hifonics hfi2500.1@2k @0.7 ohms a massive nx4 200x4rms & jensen 400 so i am putting the alt to work ...thanks guys i like the alt very much now! Quote 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing! Link to comment Share on other sites More sharing options...
MECHMAN Posted December 15, 2011 Report Share Posted December 15, 2011 Thanks for the good word! Glad this one is working out for you, that particular model it is critical to use the proper ring terminal as the connector pad is small. If you need anything you know where to find us. -Eric. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
