why do I peak so high?
Do u have any specs on the box? .5 displacement for the port don't seem right in a box that big. Also what car
28hz port is port up! when I remove it 43hz port is port back, 28hz port slips into the 43hz port, then L's out to top of box making it port up
how much room is between the 43hz port & ur cargo door? what is the height & width of the port?
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
42552aa7.jpgthis pic is the 28hz port it is 6.25in tall, 30in wide, 35in deep.but only 15in of it goes into box. it is shaped like a L, when i remove the 28hz port it becomes a normal sub up port back box tuned to 43hz port is [7.75in tall, 31.5in wide, 11in deep. 43hz port has 8in from back hatch to breath.
internal box volume before sub and port displacements is 17.8, outer mesurements are 23in tall, 45in wide, 36in deep. double baffle, dowel bracing
  • Who's Online   1 Member, 0 Anonymous, 614 Guests (See full list)
