dbwesz Posted November 23, 2007 Report Share Posted November 23, 2007 i've a question. i've 4 RF t30001bd amps and i've link them. like master , slave, slave, slave i wanne put an bass control on it like rockford deliver by every t30001 and other amps. how do i've to connect a bass remote in this instalation, I KNOW THERE IS AN CONNECTION ON EVERY AMP, but in this setup how do i have to connect them?? just 1 remote bass on the master amp of what ??? Quote Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps Link to comment Share on other sites More sharing options...
ChevyBoy Posted November 23, 2007 Report Share Posted November 23, 2007 i believe it is just the master amp. Quote Link to comment Share on other sites More sharing options...
dbwesz Posted November 23, 2007 Author Report Share Posted November 23, 2007 yeah me 2 cause you set in a setup like this everything with the masteramp, i dont think that i've to put in every amp an bass remote Quote Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps Link to comment Share on other sites More sharing options...
dbwesz Posted November 23, 2007 Author Report Share Posted November 23, 2007 some people know more about this ???? Quote Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps Link to comment Share on other sites More sharing options...
cmrs2k Posted November 23, 2007 Report Share Posted November 23, 2007 (edited) Hook up one remote knob to the Master amp. That is all. As long as you are running your signal (RCA) from the master to slave, to slave, to slave, etc. it will work fine. That is how I am set up now. Works perfect. Reason for edit: Correct Spelling Edited November 23, 2007 by cmrs2k Quote Link to comment Share on other sites More sharing options...
dbwesz Posted November 23, 2007 Author Report Share Posted November 23, 2007 yeah ive it like that, master to slave to slave to slave, with 2 BD syncs and the RCA's like they have to be. BUT THNX Quote Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps Link to comment Share on other sites More sharing options...
cmrs2k Posted November 23, 2007 Report Share Posted November 23, 2007 Excellent. Just run your remote cable from the master amp to where you want the remote and plug it in. Should be good to go. Good luck. Quote Link to comment Share on other sites More sharing options...
dbwesz Posted November 23, 2007 Author Report Share Posted November 23, 2007 i gonna try it just try how it will sounds cause is already loud. Quote Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps Link to comment Share on other sites More sharing options...
dbwesz Posted November 23, 2007 Author Report Share Posted November 23, 2007 one little last question more. there 2 buttons on it, a bass boost button but what is the right button ?? HZ or what do i have to do with it ?? Quote Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps Link to comment Share on other sites More sharing options...
cmrs2k Posted November 23, 2007 Report Share Posted November 23, 2007 one little last question more.there 2 buttons on it, a bass boost button but what is the right button ?? HZ or what do i have to do with it ?? That one sets your center frequency. It is just an additional control that RF allows you to have at your drivers seat. Just set that based on your center tuning frequency. Sometimes you might have to adjust it a little bit while you listen, and even better if you have a SPL mic (termlab, audiocontrol, etc.) to see what gives you the best results. Quote Link to comment Share on other sites More sharing options...
