weird thing
miniSPLlancer
you got less than 20 responses and you're already giving up because someone questioned how you got 51hz...
wow
is the dual 10" box sealed off firing forward?
It's not that I'm giving up bro, I'm not mad or anything, I take in what everybody says, with that being said, my last 3 boxes are as follows
4th order, 2 sundown sa-12's, same amp, tuned to 32hz, peaked at 28hz
2 sundown sa12's tuned to 43hz, peaked at 48hz
This box, 2 HDC310's tuned to 35hz, peaked at 33
The last two were regular slot ports
It's just weird to me, I'm not gonna say there's no way my box can't wrong, it's possible, I just think it weird, I use Torres, did as showed, I'm just stumped that's all
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
wow
Yes, it's not sealed off yet, rebuild is currently in progress
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
So it's firing forward or backwards?
The 4th order is peaking lower, because that's what they do.
I've heard taht HDC's like high tuning so tuning them to that "low", would make them peak below port tuning.
I've had this happen with other woofers.
It could also be because you are firing forward and it's not sealed off yet, you get weird results because of the waves cancelling each other out at higher frequencies.
And if you are firing backwards, something "similar" could happen.(most of the times that happens when the box is close to the trunk itself, or when the port "extends" because your trunk is barely bigger then your box and the room between the box and car/trunk acts like a "port")
Show a picture of how it's setup.
box is I think 10in front the trunk, iirc
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
Rear deck also sealed off? Can't see it from the pictures.
What car is it? Mitsubishi lancer? which year?
rear deck is done from underneath haven't done the top yet, and yes 2008 Mitsubishi Lancer
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
  • 3 weeks later...
If the top hasn't been done yet, that's where you get your cancellation from.
Yeah, rear deck hasn't been deadened yet, and subs haven't been sealed off from the trunk yet, just got some more stuff in today for my rebuild so everything will get done eventually. One month at a time lol
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
My 15" HDC3's were tuned to 35 and also peaked at 33 in my vehicle and I used a different calculator.
When I dropped from 2Ω to 1Ω on the same amp, subs and box, my peak rose to 36hz.
Nothing to be worried about, OP.
If I went by what my Bronco peaks at, all of my boxes are way below that.
Truck is ~64hz.
Truck is ~64hz.
The Bronco probably also has a little peak at 33hz. It's the combination of the box and the car's frequency responce that causes a peak.
It's quite unusual that the peak jumps when you apply more power. Normally the peak drops the frequency.
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
