I think it says in the owners manual to set the eq to flat as well as any other settings on the deck. What i did was set it were i listen to my music to and adjust from there. As far as the bass knob, set it to a point like half prior to adjusting the gains. once its at half, adjust your gain to distortion is detected, then back down till no more.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
ohh ok sounds good. Imma check out the manual if its online somewhere, which im assuming it is.
Also, do you plug the black probe to where the actual ground is, or into the ground input on the amp?
Amp ground. Follow this link and you will find the manual on this page... http://www.wccaraudio.com/distortion-detector/smd-distortion-detector-dd-1.html This will explain step by step on how to do it.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
