MatthewSladeBrake Posted December 20, 2011 Report Posted December 20, 2011 I'm currently doing a new build for my 2001 Buick Century. I'm planning on building an enclosure for four Kenwood KFC-W3013PS subwoofers on a Hifonics HFI2000D Subwoofer: http://www.sonicelectronix.com/item_33467_Kenwood-KFC-W3013PS.html Amplifier: http://www.sonicelectronix.com/item_22702_Hifonics-HFi2000D.html I can design the box and whatever, but I really don't want to put forth the effort into figuring out all the sizes of wood I would need to make this build possible. The dimensions for my trunk are roughly - Width = 40 inches Height = 18 inches Depth = 50 inches If anyone could help me find the dimensions for the box that I would need that would be great. Other wise I will just have to stick with making four sealed boxes and using more wood to combine them all in to one box.
121ak Posted December 20, 2011 Report Posted December 20, 2011 I used the box calculator but my only issue is designing your port. Anyone with more experience? Mobile Electronics Certified Professional (MECP) Certified - Best Buy Autotech Certified
alaskanzx5 Posted December 20, 2011 Report Posted December 20, 2011 wel if your looking for a ported box then 16in high by 37in wide by 37.75 deep. 4 round ports 5in in daimeter and 10 in long. after all 4 sub in the box will be 10.02 cu ft tuned to 34.92hz. its a huge box. if you want sealed you could do a box 16in high 31in wide and 31in deep a slot ported box would be harder to do with how much more room you would need. the size difference between the ported box and sealed box is not much. i would go with the ported box, just my thought t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
MatthewSladeBrake Posted December 22, 2011 Author Report Posted December 22, 2011 wel if your looking for a ported box then 16in high by 37in wide by 37.75 deep. 4 round ports 5in in daimeter and 10 in long. after all 4 sub in the box will be 10.02 cu ft tuned to 34.92hz. its a huge box. if you want sealed you could do a box 16in high 31in wide and 31in deep a slot ported box would be harder to do with how much more room you would need. the size difference between the ported box and sealed box is not much. i would go with the ported box, just my thought Would the round ports be inside the enclosure? Or would they be on the outside of the enclosure?
alaskanzx5 Posted December 22, 2011 Report Posted December 22, 2011 inside t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
