I am debating on whether to get 2 2500s strapped at 2 ohms or a 4500 at 1 ohm? The system is going to be 2 ns v2 15s in a 6.25 cube box @ 33 hz with 116 sq inches of port sealed off from the trunk firing forward. Electrical is 2 runs of 0 gauge, 2 xspower d3100 batteries and a excessive amperage 200 amp alternator. I want the most power output with the least impedance rise, Let me know if you have experience with testing these amazing amps :)
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
I would put my money on the 2500s, when I scope mine they give clean signal up to around 3200 watts at 14.4, but thats not clamped numbers.
Edited by fritosaregood
Why not strapped at 1ohm? Id do 2500s
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
wont that void warranty and damage amps? Im going to use this for daily use, plus competition
Team gg.
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
