What can cause constant static?
I just put a kenwood radio in my girlfriends sunfire and all the speakers are really staticy. When you put the fader to the front you get no sound but the speakers all work when the fader is at 0. I have no idea what the problem is! I need help! We had to purchase a GMOS - 04 to use for the wire harness
I don't have the antenna connected cause I need to get an adapter, but it's grounded through the harness, do I need to do more than that?
It's staticy while playing a cd and usb
change the ground from the harness over to the chassis, if not that, check your wiring
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   0 Members, 0 Anonymous, 1540 Guests (See full list)
