yeah try it both ways and see which sounds better to you man
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
I get 9^3 gross, so you're probably way on the small side with port/subs subtracted.
What are specs for the port opening? I see 15.5 high, but how wide is it?
How does it sound so far as this box "seems" to be way out of whack for those subs...
the opening of the port is 4.25". And hits pretty good on some songs and sounds bad on most. i had a buddy design it and i juta put it together :shrug:
I have 2 15" Memphis CM Mojo's in the trunk of my 04 Impala SS and subs firing to the rear with the back seats down is the loudest and there is a HUGEEEE audible difference between seats up and seats folded down. My seats are 60/40 folding seats and even just having the one seat down makes a huge difference
2004 Impala SS (2 Tone)
Kenwood DDX-512 (Nav,XM,Bluetooth,Ipod)
Optima Yellowtop
240amp PB Alternator
ZZP S2 Volt Booster
Stinger SPV70 Battery(Trunk)
Big 3(x2) Monster 1/0
50ft Monster P400 1/0
Monster I401 2C-4M RCA
Memphis 16-VBF1 Line Driver
Memphis 15-MCC6 6.5" Comps
Memphis 15-MC92 6x9" Rears
15" Memphis CM Mojos
Custom 4.3cube @32hz Enclosure
Digital Deisgns M3a(Black)[email protected]
"Yes I hear you...But can you feel me?"
I tuned mine to 32hz and it sounds great and leaves alot more volume for the subs due to the smaller port
Optima Yellowtop
ZZP S2 Volt Booster
Sorry to say but that box design is junk for those subs. 8cubes NET is the smallest I'd do, 8.5-9 is better with 16^2 port per cube. You're around 10^2 per cube if you're lucky and it's tuned way too low.
If you give me your max dimensions I'll see if I can come up with a better design that will fit.
How much power do you have?
I wouldn't worry about forward/rear firing right now as your box is just too far off to get much out of those subs...
OP you must listen to this man.
max dimmensions are 38Wx17Hx40D and at 2ohms i can run 500rms to each and at 1ohm i can run 750rms to each.
  • Who's Online   0 Members, 0 Anonymous, 586 Guests (See full list)
