Mr.Aircooled Posted January 1, 2012 Report Posted January 1, 2012 i have two kicker comp 10's and this MA M600 2ch amp i wanted to run the subs in parallel and bridge them but i dont know if the amp would be safe bridged at 2 ohm. if its not would there be a way for me to bridge them at a higher impedence BOOZE IS FOOD
Mad_Mike Posted January 1, 2012 Report Posted January 1, 2012 Are the 10's single coil or dual? If single, what impedance? If dual, what impedance are each of the coils?
Mad_Mike Posted January 1, 2012 Report Posted January 1, 2012 Actually No, that amp is only stable at 4 ohms bridged. You can't bridge those subs to this amp in any way to get more power than you'd get with them just on each channel if they're single 4 ohm coil subs. If you're looking for more power, then look into a mono amp that can do (Your subs RMS wired together) @ 2 ohms. If they RMS at 300w each, look for a 500-600w RMS @ 2 ohms mono amp. Class D Mono amps are always better for sub applications.
Mr.Aircooled Posted January 1, 2012 Author Report Posted January 1, 2012 yeah svc 4ohm i was looking at mono amps but i got a really good deal on the MA. If it puts out its rated rms i think it should power them fine i just wondered if i could bridge them. BOOZE IS FOOD
