DC Sound Lab
how to wire d1 sub
hi all
i have 1 dc XL 15" sub its d1 sub
can any show me pics how to wire it and wht will be wiring configuration as well?
my amp is mono channel(2 +ve and 2 -ve terminals)
thnx
Edited by ali888
@My OpiniOnZ MAy HaVe ChanGeD, But Not The Fact ThAt I'm Right.........!!
the12volt.com
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
lmao how the hell do you have a mono 2 channel?
mono means 1
and your choices are .5 ohms or 2 ohms
being you dont even know what a mono amp is wire it to 2 ohms
one + to the other side of the subs - then the other + to the amp and the other - on the other side of the sub gos to the amp as well
mono means 1
lols
like opti 6kd it has 1 channel ouput 1+ve and 1-ve
if amp like ddz1a has 2+ve and 2-ve wht u call them 1 channel??
mono means 1
lols
YES!!!! they are intrenally linked there is only 1 channel there are 2 + and 2 - to make it easyer to hook up multi subs thats it! there still going to 1 + and 1 -
lmao
Mono means 1, They put 2 + and 2 - for easier wiring for people, they both go to the same (only) channel.
ok my mistake but i wrote for my easyness 2 channel output...so now 1 channel output fine!!!
mono means 1
lols
its still a 1 channel amp. It just has more speaker terminals to put more wire in. For like running 2 subs you can run all 4 terminals and not have to bunch up your wire into 2.
Edited by FroznBeavrBALLs
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
mono means 1
lols
lmao
ok
  • Who's Online   1 Member, 0 Anonymous, 2027 Guests (See full list)
