dwright27 Posted January 5, 2012 Report Posted January 5, 2012 Strapped at 1 is .5 per amp. Strapped at 2 is 1 ohm per amp So I would be strapped at 2ohm with 4 Dual 1 subs correct? You can yes. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 strapping is different for each amp. check your manual or go to the videos and how to on this forum. you need this special cable(forget name) and the you strap them using speaker wire, when you strap its like one big amp though with only on set of wire outputs( 1 pos and 1 neg) iirc, so maybe you want each amp to have 2 subs instead of strapping. Back in the day you're correct. Needed a bridging module. Now just one side of a spare RCA. dont you need to use the negitive on the slave and positive on the master and then connect negitives or something of that nature ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
LoudNLow931 Posted January 5, 2012 Author Report Posted January 5, 2012 Strapped at 1 is .5 per amp. Strapped at 2 is 1 ohm per amp So I would be strapped at 2ohm with 4 Dual 1 subs correct? You can yes. I'm just trying to decide if I would be better off strapping 2 DC5ks or getting a DC12k and running it at 0.5 per channel. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 not to get off topic but why you rebuilding . didnt you jsut build those 2 15's ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
dwright27 Posted January 5, 2012 Report Posted January 5, 2012 Yes to both of Mikeys questions. 12k is 2 5ks strapped internally. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
MIKE-2U Posted January 5, 2012 Report Posted January 5, 2012 so when you strap amps does that only leave on positive output and on negitive output ? because the two negitives are tied togeter? I feel like a 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
LoudNLow931 Posted January 5, 2012 Author Report Posted January 5, 2012 Yes to both of Mikeys questions. 12k is 2 5ks strapped internally. So if I just got another 5k and strapped them it would be the same pretty much, Might as well go that way. 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
dwright27 Posted January 5, 2012 Report Posted January 5, 2012 Yea ^^^ pretty much Joe. Mike, the positive terminals of the master amp get the positive speaker wire. The positive terminals of the slave amp get the negative wires. Then you wire the negative terminals together from master to slave 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
LoudNLow931 Posted January 5, 2012 Author Report Posted January 5, 2012 Then this is how you strap them correct? 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
