Alrighty... Say I have 4 Dual 1 subs and 2 DC5ks, How do I wire the subs to both amps and what kinda load would each amp see? I wire 2 subs to each amp so each amp was 1ohm and then strapped the load on each amp would be what? i have no idea about how strapping works...
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
Each amp will see half of your final load
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Strapped at 1 is .5 per amp. Strapped at 2 is 1 ohm per amp
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
strapping is different for each amp. check your manual or go to the videos and how to on this forum. you need this special cable(forget name) and the you strap them using speaker wire, when you strap its like one big amp though with only on set of wire outputs( 1 pos and 1 neg) iirc, so maybe you want each amp to have 2 subs instead of strapping.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
So I would be strapped at 2ohm with 4 Dual 1 subs correct?
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
its not a special cable you can use one side of some short rcas
MY BAD
Back in the day you're correct. Needed a bridging module.
Now just one side of a spare RCA.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Series resistance adds, parallel resistance take a little more math. For parallel, you do
you should not mix different ohm loads however. The easiest way to do parallel loads though, as long as every load is the same (i.e. 2 d4 subs) is if every load is in parallel: then take the ohm load divided by the number of loads. so 2 d4 subs= 4 coils at 4 ohms. if all are in parallel, then 4/4=1.
Say you had 6 single 8 ohm subs and you want to put all of them in parallel. 8ohms/6loads=1.33ohms.
now if you had different load values (which you should not do unless you KNOW what you're doing) then you would have to use the equation listed above.
****this is waht some one shoulded me when i was wiring my 2 d-4ohm subs. you take ohm load( 1 ) dived by coils( 4 since there are each DUAL) so 1/4= .25 but if your strapping it would be .5 ohm and each amp sees .25
