you really shouldn't need the brace in the port unless the sub is firing up.
it's an L5, i'm assuming not seeing that much power. my buddy overpowered his 10" L5's in the standard kicker box, and had no problems.. if anything i'd do a double baffle
ok, the sub and port are going to be facing the rear hatchback, so i should be able to get away without any bracing? and its a 600 watt rms mb quart amp.
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
usually i like to add some bracing. if you have wood leftover, i'd do a double baffle.
as in 2 pieces on the front? cause we did get a second front piece made as we where planning to make it flush. and again, thanks everyone really appreciate all the help
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
yes, the piece of wood that the subwoofer sits on is called the baffle. if you were planning on doubling up to make it flush you should be good. no bracing required.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
  • Who's Online   1 Member, 0 Anonymous, 1559 Guests (See full list)
